User defined Coil Geometry- Square shape PM and Coil- Moving mesh
I have modelled a square shape coil and square shape permanent magnet (PM).
In my model, square shape PM can move in z direction, but there is no motion for the coil.
My problem is with using the current flow in the coil as I am using user defined coil geometry for my model because I cannot use linear or circular type coil for the considered geometry of the coil.
I don't know how I can define coil current flow in user-defined coil geometry.
I run the model and for the time dependent part the obtained current is zero but it shouldn't be because there is a relative motion between coil and PM, and I think it is related to defining coil-current flow.
Please note initially the considered current for the coil is zero, but we must have induced current in the coil because of having relative motion between coil and PM, and accordingly, change of magnetic flux density.
It would be great to help me for it.
Thanks, Ehsan
0 Replies Last Post 13 mai 2016, 19:48 UTC−4
Hello Ehsan Asadi
