visualising subdomain expresions
I used Boundary Distance Variable to separate a subdomain into two parts - one was embedded inside the other. (because of the complex and irregular geometry it isn't possible to divide the subdomain using the draw tools)
Expressions were defined for each part.
Now I want to visualize the solution only in the inner part. Is there a certain way that I can make the outer part completely transparent and visualise the solution only in the inner part? I have tried to change the colour scale settings in post processing but unfortunately these don't allow us to use transparency as a colour.
Thanks for any tips
Amr
1 Reply Last Post 12 oct. 2009, 01:48 UTC−4
Posted: 2 decades ago 12 oct. 2009, 01:48 UTC−4
When working with complex geometry (before the solution is there) you have the "hide element" and "show all" that allows you to reduce the complexity of the apparant geometry, this is handy for picking small features ans setting up BC (boudary consitions on complex systems), unfortunately there is no simple tick list to select items per name, you must use the mouse, item per item, and at best get them all back and re-start from scratch in case of error.
Then for postprocessing, in the "General" tab you have the "Elemen" tick box, thereafter you can select limits such as (x<100) or (x<100)*(y<10) etc, but yo can also make more complex selections
More in the documentation, about postprocessing and plots
Hope it helps
Hi When working with complex geometry (before the solution is there) you have the "hide element" and "show all" that allows you to reduce the complexity of the apparant geometry, this is handy for picking small features ans setting up BC (boudary consitions on complex systems), unfortunately there is no simple tick list to select items per name, you must use the mouse, item per item, and at best get them all back and re-start from scratch in case of error. Then for postprocessing, in the "General" tab you have the "Elemen" tick box, thereafter you can select limits such as (x
