What causes a model to converge at one frequency, but not at another?
I have created a coil and am running it at different turn number and frequencies to verify that the model is outputting correct inductance.
Using "magnetic and electric fields" (mef) and a frequency domain study, I am running the following parametric sweeps:
N=5,10,15 turns
f = 10, 50, 100, 500 Hz
However, after running N=5 through all frequencies, N=10 does not converge at f=500 Hz.
Does anyone have any tips on how to tweek the solver?
I am currently running FGMRES and it "slows down" between a convergence of 2-5 while SSOR iterates to 1 000 000 and it gives up.
3 Replies Last Post 2 mai 2016, 14:57 UTC−4
Posted: 8 years ago 1 mai 2016, 14:53 UTC−4
I believe you do not give us enough info to give back reasonable guesses.
One possibility, taken from the blue, with N=10 and f=500Hz you are hitting a LC resonance without any resistance to damp the signal hence a numerical singularity, but it could be fully other things, like a mesh density issue ...
Hi I believe you do not give us enough info to give back reasonable guesses. One possibility, taken from the blue, with N=10 and f=500Hz you are hitting a LC resonance without any resistance to damp the signal hence a numerical singularity, but it could be fully other things, like a mesh density issue ... -- Good luck Ivar
Posted: 8 years ago 1 mai 2016, 15:39 UTC−4
Greetings, Ivar. It is an honor to have you in my thread :)
My fault is almost bordering idiotic, but I forgot to disable the study "coil geometry analysis" after disabling the multiturn coil.
After that it worked out nicely, and I got good results:
Physical inductor: measured by impedance method at 128 uH
Modelled replikaka in comsol: 126.55 uH
I hope it's not pure dumb luck
[QUOTE] Hi I believe you do not give us enough info to give back reasonable guesses. One possibility, taken from the blue, with N=10 and f=500Hz you are hitting a LC resonance without any resistance to damp the signal hence a numerical singularity, but it could be fully other things, like a mesh density issue ... -- Good luck Ivar [/QUOTE] Greetings, Ivar. It is an honor to have you in my thread :) My fault is almost bordering idiotic, but I forgot to disable the study "coil geometry analysis" after disabling the multiturn coil. After that it worked out nicely, and I got good results: Physical inductor: measured by impedance method at 128 uH Modelled replikaka in comsol: 126.55 uH I hope it's not pure dumb luck -- :)
Posted: 8 years ago 2 mai 2016, 14:57 UTC−4
It's never to late to learn ;)
and we learn more from our "errors" often, than from our successes, so continue like that :)
Have fun COMSOLing
Hi It's never to late to learn ;) and we learn more from our "errors" often, than from our successes, so continue like that :) -- Have fun COMSOLing Ivar
