Eigen Frequency for Predeformed membrane
Dear All
Please tell, How can I run Eigen Frequency Simulation on predeformed membrane.
Regards
Anil Arora
3 Replies Last Post 14 nov. 2010, 08:55 UTC−5
Posted: 1 decade ago 9 nov. 2010, 23:57 UTC−5
Anil Arora
-- Anil Arora
Posted: 1 decade ago 10 nov. 2010, 02:34 UTC−5
there are a few threads about this, try a search on the Forum.
Basically in 3.5 you need to run via matlab a stationary case, store the solution and use it as the starting point for a linearization of the eigenfrequecy analysis.
In V4 you can achieve this fully within the GUI environment. in v4.1 you add a stationary followed by a eignefrequency one after the other, ask for the default solver and check that they eare done in two steps with a store solution in between, and that the eigenfrequency initial conditions are taken from the stored solution.
an V4.0 you need to build the solver sequence partly by hand
As an example, try a buckling model in structural, I believe the re is one in the model library
Hi there are a few threads about this, try a search on the Forum. Basically in 3.5 you need to run via matlab a stationary case, store the solution and use it as the starting point for a linearization of the eigenfrequecy analysis. In V4 you can achieve this fully within the GUI environment. in v4.1 you add a stationary followed by a eignefrequency one after the other, ask for the default solver and check that they eare done in two steps with a store solution in between, and that the eigenfrequency initial conditions are taken from the stored solution. an V4.0 you need to build the solver sequence partly by hand As an example, try a buckling model in structural, I believe the re is one in the model library -- Good luck Ivar
Posted: 1 decade ago 14 nov. 2010, 08:55 UTC−5
Thanks a lot.
I will try it in V4.1
Anil Arora
Thanks a lot. I will try it in V4.1 -- Anil Arora
