Voltage Induced in a Coil by a Moving Magnet
Posted 2 févr. 2016, 03:21 UTC−5 Low-Frequency Electromagnetics, Mesh Version 4.4 2 Replies
Dear COMSOL Community,
I am currently running a simulation which is almost identical to the tutorial on "Voltage Induced in a Coil by a Moving Magnet (I have attached the file for easy reference).
However, I want the magnet to move at a fixed linear velocity (of 60mm/s) instead of oscillatory as modeled in the tutorial. May I know how I should go about doing this?
Should I continue using Prescribed Mesh Displacement to move the magnet domain, or should I use the Prescribed Mesh Velocity setting instead? I have tried using Prescribed Mesh Velocity settings however I get an error message of "failed to find consistent initial values. last time step is not converged."
Any help is very much appreciated!!!
2 Replies Last Post 11 févr. 2016, 04:03 UTC−5
