Simple 2D Flow Problem but no convergence
Hi All,
I am trying to simulate very simple fluid flow with an inlet and outlet boundary conditions but I am having trouble with convergence. For some reason, my result would not converge. I was wondering if any of the experts could have a take a look at the model I have and help me with it.
I have an air flow inlet with a specified air flow speed and an outlet. The rest of the geometry is wall.
Please share your thoughts.
thanks,
1 Reply Last Post 22 janv. 2016, 03:09 UTC−5
Posted: 9 years ago 22 janv. 2016, 03:09 UTC−5
Hello
Actually it’s not a very simple geometry :-)
I tried to reduce the inlet speed and changed a bit the solver configuration.
If you run the simulation you can see that the circles in your model and its curvature create wakes that destabilize the flow.
I think you should use the turbulent flow module in this case (which I don’t have)
Dara
Hello Actually it’s not a very simple geometry :-) I tried to reduce the inlet speed and changed a bit the solver configuration. If you run the simulation you can see that the circles in your model and its curvature create wakes that destabilize the flow. I think you should use the turbulent flow module in this case (which I don’t have) Good luck Dara
