time of running
i just want to know how can i know how much time my model takes until arrive to final results. it is very important things for me to compare with time of running until arrive to final results
thank you
2 Replies Last Post 21 janv. 2016, 12:44 UTC−5
Mao COMSOL Employee
Posted: 8 years ago 21 janv. 2016, 09:42 UTC−5
Dear Ali,
For a specific model, it will be very difficult to predict the computation time, without running some tests. If possible, you can run your model with a coarse mesh, then gradually refine your mesh, and see how the computation time increases with mesh refinements (# of DoFs).
You are also welcome to contact COMSOL technical support via support@comsol.com.
Hope this helps.
Mao
Dear Ali, For a specific model, it will be very difficult to predict the computation time, without running some tests. If possible, you can run your model with a coarse mesh, then gradually refine your mesh, and see how the computation time increases with mesh refinements (# of DoFs). You are also welcome to contact COMSOL technical support via support@comsol.com. Hope this helps. Mao
Posted: 8 years ago 21 janv. 2016, 12:44 UTC−5
Thank you
Thank you
