No Terminal BC in 5.2?
I recently switched to COMSOL 5.2, and am building a pretty simple piezoelectric model with the Piezoelectric Devices module (Solid Mechanics + Electrostatics). In the past, I've used a Terminal BC to apply voltage, so that impedance and other lumped parameters are calculated in the result. But I don't see the Terminal BC option in Electrostatics anymore - just Electric Potential. Am I missing something?
Thanks!
Jillian
1 Reply Last Post 19 janv. 2016, 09:16 UTC−5
Posted: 8 years ago 19 janv. 2016, 09:16 UTC−5
Just an educated guess: Could it be that your license for version 5.2 does not include the same set of modules as you had before? Some boundary conditions are only available through certain modules.
Just an educated guess: Could it be that your license for version 5.2 does not include the same set of modules as you had before? Some boundary conditions are only available through certain modules. Jeff
