How to export far-field pattern for a parameter sweep
Posted 18 nov. 2015, 04:49 UTC−5 Acoustics & Vibrations Version 5.1 0 Replies
phi1 theta1 pfar11 pfar21 pfar31 ...
phi2 theta2 pfar12 pfar 22 pfar 32...
The first two column is the fixed values of phi and theta angles where the far-field pattern are evaluated.
The rest of the columns are the value of the far-field pattern for each incident angles in the parameter sweep.
Alternatively, it's ok to export the far-field pattern to individual files with parameter dependent file names, such as
pfar1.csv pfar2.csv, ...
Hello Yuliang Wang
