Intermetallic formation
Posted 15 nov. 2015, 18:15 UTC−5 0 Replies
I have a problem which has to be solved using phase field and diffusion equation. the geometry i made it in COMSOL 5.0. Here i have two pure metal (Sn and Cu). I will put a temperature profile (maximum temp. 260 degree Celsius constant for 10 min, heating:20 degree/min, cooling: 20 degree/min). I need to show how intermetallic (Cu6sn5, initial thickness 3 micrometer) grows over time with temperature profile.
Is it possible to simulate above scenario using COMSOL 5.0. I'm using Academic Kit license. I attached the geometry and material in the project.f anyone can suggest me i'll be so grateful then.
Thank you in advance.
Best Regards,
Tito
Hello Chironjeet Chaki
