step-by-step instruction, report generator
Posted 16 sept. 2010, 13:54 UTC−4 2 Replies
Dear all
Has someone investigated how to generate a step-by-step instruction from a Comsol java (or .m) file? (the .mph file is a zip file with some .xml files inside, so the procedure should be similar)
If I open such files in a plain text editor, I can see the whole model tree encoded in an object oriented fashion. I would like to clean out the rubbish an get a simple text file with the steps like:
1.- Select 3D
2.- Add "Time-dependent study"
3.- Add "Laminar Flow"
4.- Go to Geometry, create a 1x10 rectangle
5.- Add basic material, water
6.- press Solve
7.- Plot velocity field
etc....
I wander if there is such a nice piece of code circulating in the forum... thanks
john.
1.- Select 3D
6.- press Solve
etc....
john.
2 Replies Last Post 17 sept. 2010, 12:03 UTC−4
