Henrik Sönnerlind
COMSOL Employee
9 years ago
6 nov. 2015, 10:00 UTC−5
Here is how to do it:
1. Model the two points where you want the hinge to connect slightly apart from each other, so that the beams will be disconnected at that location.
2. Add one Attachment to each of the two points (found under Connections).
3. Add a Multibody Dynamics interface and select the appropriate joint type. In the settings for the joint, pick up the two attachments.
4. Add more settings to the joint e.g. the location of the center of the hinge.
Henrik
Henrik
9 years ago
9 nov. 2015, 06:20 UTC−5
It does work as intended.
Thanks alot!
Thanks alot!
9 years ago
10 nov. 2015, 09:00 UTC−5
hi, I want to do the same with stationary study, and I cant do it. Any idea?
Henrik Sönnerlind
COMSOL Employee
9 years ago
10 nov. 2015, 12:08 UTC−5
This approach is independent of study type.
Henrik
Henrik
9 years ago
11 nov. 2015, 15:17 UTC−5
Thankyou for your answer, but in solid mechanics, I cant find the option attachment and the hing connection
Henrik Sönnerlind
COMSOL Employee
9 years ago
12 nov. 2015, 05:49 UTC−5
If you have a license for the Multibody Dynamics Module, then the approach is the same when using Solid Mechanics.
If not, you can use the method shown in the model "Assembly with a Hinge" (in the Connections and Mechanisms folder under Structural Mechanics). You can also find this model in
www.comsol.com/model/assembly-with-a-hinge-10569
Henrik
http://www.comsol.com/model/assembly-with-a-hinge-10569
Henrik
9 years ago
12 nov. 2015, 09:57 UTC−5
Ive just realized that my software is damaged, im reinstalling again, for this reason I couldnt find the option multibody dynamics, thanks for your help
