Permanent magnet constitutive relation
Hey guys!
I'm trying to model a system of permanent magnets and was just wondering what the constitutive relation should be used: the magnetisation one B = \mu_0H + \mu_0M, or the remanent flux one B = µ_0µ_rH + ???B_r ?
From what I've seen, both seem to be used in the literature...
Thanks for the help :)
- Milly
1 Reply Last Post 10 sept. 2010, 04:43 UTC−4
Posted: 1 decade ago 10 sept. 2010, 04:43 UTC−4
both are equivalent if you apply the physics correctly and you input the correct values, I mostly use the Magnetisation fr permanent magnets, as it's often what I have as "correct" specified values
Hi both are equivalent if you apply the physics correctly and you input the correct values, I mostly use the Magnetisation fr permanent magnets, as it's often what I have as "correct" specified values -- Good luck Ivar
