Exporting matrices using Comsol Livelink to matlab
Esubalewe Lakie Yedeg
I am working with a wave propagation problem in weak form( as given in the attached file). I have implemented the weak form in COMSOL and I solved the problem. That is perfectly fine.
I want to export the associated matrices to MATLAB for further use.
I read the section "Working with Matrices" in the LiveLink for MATLAB User's guide and I am using the "mphmatrix" function to extract matrices.
I thought, according to the documentation, the command
MA = mphmatrix(model,'sol1','out',{'K','E'}); gives me stiffness matrix MA.K and mass matrix MA.E ( cooresponding to the first and second integral, respectively, in equation (2) of the attached file).
BUT I AM NOT SURE IF THAT IS TRUE. Because mass matrix MA.E is a zero matrix of size(MA.K) and the stiffness matrix is not symmetric.
Moreover, I am looking to export boundary matrices corresponding to the integral over inlet-outlet boundary $\Gamma_{\textrm{io}} $ and interface boundary $\Gamma_{I} $.
I am looking for an idea how to export matrices cooresponding to each integral.
Thank you in advance,
Esu
2 Replies Last Post 7 sept. 2015, 09:47 UTC−4
Posted: 9 years ago 7 sept. 2015, 09:46 UTC−4
Usually, I divide the weak form into two mph files.
Then Still export "stiff matrix" even if the weak form seems like
u*test(u) !
You can try this. I think mass matrix maybe only work well with "ut*test(u)"
Math Phd_ing
Usually, I divide the weak form into two mph files. Then Still export "stiff matrix" even if the weak form seems like u*test(u) ! You can try this. I think mass matrix maybe only work well with "ut*test(u)" -- Math Phd_ing
Posted: 9 years ago 7 sept. 2015, 09:47 UTC−4
u*test(u) !
Math Phd_ing
