Writing a 'if' function for the surface boundary condition
Posted 7 août 2015, 09:57 UTC−4 Modeling Tools & Definitions, Parameters, Variables, & Functions Version 5.0 0 Replies
İ want to make a boundary condition for a density change according to temperature on the surface.İ made a PDE(using heat equation for both i just changed the units for the density) for heat and density one of them calculates temperature and the other uses the results of the first PDE to find density.
İ found out that i can type u(result of the first equation) in the second equations boundary condition as a function to find u1(density result).
So my question is for the surface density i want it to take the temperature for the respecting time step and use that temperature to find density at that respective time but if the result for density on the surface is higher than 0.1 i dont want it to use that result instead i want it to take the density 0.1 at that time step.
So i wrote something like this and hoped it would work bu it didnt :(
min(611*exp(-6141.207601636*((1/u)-0.003660858105)),0.1)
İ hope i did explain myself i just couldnt figure it out if someone could help me that would be great .
PS when i wrote like min(1,0) it gives me the result of 0 maybe its because one ofe the function parameter is a function as well but i dont know i hope i can do something like that on COMSOL.
Hello Hakan Tarık Meriç
