parametric sweep and post processing => data set => cut line
for a cylinder with PARAMETRIC SWEEP over length of it, i have defined a CUT LINE across circular surfaces of the cylinder by giving parameter values in LINE DATA. Problem is that it is taking parameter value which is given at GLOBAL=>DEFINITION=>PARAMETERS, and not the values given in STUDY=> PARAMETRIC SWEEP=> STUDY SETTING, due to this i am not getting results in post processing.
2 Replies Last Post 15 août 2015, 10:07 UTC−4
Posted: 10 years ago 31 juil. 2015, 02:13 UTC−4
model file attach with this post
KSM
model file attach with this post -- KSM
Posted: 10 years ago 15 août 2015, 10:07 UTC−4
I am facing the same problem. Have you found a solution?
