Can the program Comsol be used for modeling of ferroelectrics phase transition?
4 Replies Last Post 14 juil. 2010, 12:30 UTC−4
Posted: 1 decade ago 14 juil. 2010, 09:17 UTC−4
Who can help how can Comsol be used for modeling of ferroelectrics below Curie point.
Posted: 1 decade ago 14 juil. 2010, 11:05 UTC−4
Using a step function in material properties (temperature depending magnetic permeability)? But, I've never used the ACDC-Module. Is it coupled with heat transfer (-> e.g. T_htgh)?
mu=flc1hs(T_htgh-T_curie,0.5)*mu_ferro
Using a step function in material properties (temperature depending magnetic permeability)? But, I've never used the ACDC-Module. Is it coupled with heat transfer (-> e.g. T_htgh)? mu=flc1hs(T_htgh-T_curie,0.5)*mu_ferro
Posted: 1 decade ago 14 juil. 2010, 12:21 UTC−4
I want to obtain the distribution of spontaneous polarization and electrical potantial which appear in ferroelectrics below Curie point. I'm modeling a composition material consisting of dielectric matrix and ferroelectrics grains. The polarization and potential submit partial differential system below Curie point. This partial differential system is non-linear and has following view:
æ•?? + ?•? - ?•?^3 = d?/dz-E0
?•?? = 4?•dP/dz
I want to obtain the distribution of spontaneous polarization and electrical potantial which appear in ferroelectrics below Curie point. I'm modeling a composition material consisting of dielectric matrix and ferroelectrics grains. The polarization and potential submit partial differential system below Curie point. This partial differential system is non-linear and has following view: æ•?? + ?•? - ?•?^3 = d?/dz-E0 ?•?? = 4?•dP/dz
Posted: 1 decade ago 14 juil. 2010, 12:30 UTC−4
æ•div(gradP) + a•P - b•P^3 = dFi/dz-E0
epsilon•div(gradFi) = 4pi•dP/dz
æ•div(gradP) + a•P - b•P^3 = dFi/dz-E0 epsilon•div(gradFi) = 4pi•dP/dz
