error limit set
Posted 7 mars 2015, 02:25 UTC−5 Studies & Solvers Version 5.0 0 Replies
'The default setting is tol, in which case the segregated iterations are terminated when, for each group, the estimated error is below the corresponding tolerance set by the main tolerance for the parent solver multiplied with the nonlinear tolerance factor ntolfact. '
I want to know how to set the low limit of error
Hello Shin Gahui
