Empty probes when choosing not to store solutions in output
I have a working piezoelectric material model in which I use a frequency domain study to sweep the frequency; I then measure the electromechanical transduction as a function of frequency. I have defined a boundary probe that measures the current flowing through the device. The probe populates just fine when I store all the solutions in the output, but when I uncheck the "Store in output" box, the probe just returns zero for all frequencies. To be specific, I'm unchecking the "Store in output" box in the node: Study -> Solver Configurations -> Solver 1 >- Dependent Variables,
My goal is to run a large frequency sweep without having to retain the fields from each frequency step. How do I keep the accumulated probe information from every frequency step without storing all the solutions?
Thanks in advance for your help,
Matt
1 Reply Last Post 25 août 2016, 12:13 UTC−4
Hello Matt Eichenfield
Posted: 8 years ago 25 août 2016, 12:13 UTC−4
1) Study -> Parametric Sweep -> Output While Solving -> Turn on "Accumulated probe table."
2) Study -> Parametric Sweep -> Output While Solving -> Select "Only last" for Keep solutions in memory.
3) Study -> Solver Configurations -> Solver 1 -> Dependent Variables -> Turn on "Store in output" for any fields that the probes depend on.
You will still retain the fields from the last frequency in your sweep, but you will throw away the fields from all the other frequencies in the sweep, so your memory usage and file size should be manageable.
The probe data will be in the table specified in the "output table" for the accumulated probe table.
Hope that helps!
-Chris
1) Study -> Parametric Sweep -> Output While Solving -> Turn on "Accumulated probe table." 2) Study -> Parametric Sweep -> Output While Solving -> Select "Only last" for Keep solutions in memory. 3) Study -> Solver Configurations -> Solver 1 -> Dependent Variables -> Turn on "Store in output" for any fields that the probes depend on. You will still retain the fields from the last frequency in your sweep, but you will throw away the fields from all the other frequencies in the sweep, so your memory usage and file size should be manageable. The probe data will be in the table specified in the "output table" for the accumulated probe table. Hope that helps! -Chris
