RF source modeling
Posted 3 févr. 2015, 11:09 UTC−5 RF & Microwave Engineering, Geometry, Modeling Tools & Definitions, Parameters, Variables, & Functions 1 Reply
I am trying to model an RF transmitter that I am using to harvest energy in a project. The transmitter is from, powercast and the model number is TX91501. The only electrical specifications that appear in the data sheet are:
Frequency: 915MHz
Output Power: 1Watt
Beam pattern :60° width, 60° height Vertical Polarization (with logo in upright position)
Modulation Power: Direct Sequence Spread Spectrum (DSSS), Data: Amplitude Shift Keying (ASK)
I am having trouble identifying the best way to simulate this part. I want to place it below a cage and simulate power density and reflection inside of the cage. The examples that I have seen all have an electric field coming off a border line in a 2D design. But my model is 3D and I do not know how to recreate the 60 degree angle that the transmitter is outputting. Should this be done creating a port? an antenna? any suggestions are welcomed since this is my very first COMSOl project.
Thank you very much
Frequency: 915MHz
Output Power: 1Watt
Thank you very much
1 Reply Last Post 12 févr. 2015, 11:59 UTC−5
