9 years ago
26 janv. 2015, 07:10 UTC−5
You can define any variable or their combination in the plot definitions.
In the main window of Comsol model you can select the unit system; there is also a dimensionless option.
Lasse
Lasse
9 years ago
26 janv. 2015, 07:13 UTC−5
Hello Lasse:
Thank you very much for your technical help. I'll try it.
Shirley
Hello Lasse:
Shirley
9 years ago
26 janv. 2015, 07:24 UTC−5
Hello Lasse,
I have modified the model with the method you told me, but there is still some problems.
I want to repeat the model in this paper and make some improvements, draw the relations between c and dimensionless time.
Can you tell me how to achieve that??? Thank you very much.
Shirley
Hello Lasse,
Shirley
9 years ago
26 janv. 2015, 09:45 UTC−5
What's the problem? Reading the paper takes some effort...
Lasse
Lasse
9 years ago
26 janv. 2015, 20:17 UTC−5
Get a relationship curve between concentration C and dimensionless time . But in the model the default is conventional time t, even I set the unit system to be non in the main surface.
9 years ago
27 janv. 2015, 02:55 UTC−5
You need to make a global plot:
Results --> 1D Plot Group --> Global --> x Axis Data --> Parameter: Expression
There you can put your dimensionless time.
Wish this helps
Lasse
Wish this helps
Lasse
