integration over parameter instead of geometry
Dear all,
I was wondering if the following integral was possible in Comsol.
where f(g) is a known function, a,b are the limits (also known) and emw.Ex would be the electric field which depends on the position and on the value of g, i.e., emw.Ex=emw.Ex(x,y,z,g). I have seen a very similar question here: www.uk.comsol.com/community/forums/general/thread/39845 , but I have no idea have to deal with my problem. Normally, the integrals are defined over a domain, but this is not the case.
I guess that one solution would be do a Parametric Sweep over g, and make the integration in matlab, but I would like to know if this is possible in Comsol
Thank you so much
2 Replies Last Post 22 janv. 2015, 09:21 UTC−5
Frank van Gool COMSOL Employee
Posted: 10 years ago 22 janv. 2015, 05:13 UTC−5
Dear Juan Miguel,
Please take a look at the built-in operators in COMSOL, for instance the "integrate(expr, var, lower, upper)" operator.
You can find a list in the Reference Manual under "Operators, Functions and Constants".
Frank
Dear Juan Miguel, Please take a look at the built-in operators in COMSOL, for instance the "integrate(expr, var, lower, upper)" operator. You can find a list in the Reference Manual under "Operators, Functions and Constants". Best regards, Frank
Posted: 10 years ago 22 janv. 2015, 09:21 UTC−5
Thank you so much!
Thank you so much!
