Navier-Stokes, permeation boundary condition
I study on a cylindrical tube which have a Navier Stokes flow inside and outside the tube. The wall of the tube un permeable. I want to know how i can put boundary condition on the wall.
I have other phenomenons in the model like darcy and maxwell stephan diffusion.
the meeting is open
3 Replies Last Post 24 mai 2016, 15:27 UTC−4
Hello Dieng Abdoulaye
Posted: 9 years ago 20 janv. 2016, 01:29 UTC−5
Hi,i want to know whether you have solved the problem . Now i face with the same question . thank you best wishes to you
Posted: 9 years ago 20 janv. 2016, 08:36 UTC−5
A simple model that may interest you is here:
www.comsol.com/model/separation-through-dialysis-258
In that model, the velocity in the free flow regions can be assumed, so we're only solving for the concentrations.
If you wish to solve for the velocities (which seems to be the case, judging from your post), a more sophisticated approach involving the coupling of free and porous medium flow is illustrated by this model:
www.comsol.com/model/porous-reactor-with-injection-needle-25
There are several other tutorials that show how to couple free and porous medium flow in the Application Libraries for the Chemical Reaction Engineering Module (see www.comsol.com/chemical-reaction-engineering-module) and the Subsurface Flow Module (see www.comsol.com/subsurface-flow-module) if you have them on your license.
A simple model that may interest you is here: http://www.comsol.com/model/separation-through-dialysis-258 In that model, the velocity in the free flow regions can be assumed, so we're only solving for the concentrations. If you wish to solve for the velocities (which seems to be the case, judging from your post), a more sophisticated approach involving the coupling of free and porous medium flow is illustrated by this model: http://www.comsol.com/model/porous-reactor-with-injection-needle-25 There are several other tutorials that show how to couple free and porous medium flow in the Application Libraries for the Chemical Reaction Engineering Module (see http://www.comsol.com/chemical-reaction-engineering-module) and the Subsurface Flow Module (see http://www.comsol.com/subsurface-flow-module) if you have them on your license. Best regards, Jeff
Posted: 9 years ago 24 mai 2016, 15:27 UTC−4
the examples i looked but i don´t get permeation of hidrogeno.(2D)
I put a domain where the fluid goes in direction axial but the right domain is a porous membrane so the fluid to have goes also in direcction radial and third domain is permeation and goes in direcction velocity axial.
My example is similary a dialysis but my driving force is the pressure and i don´t get across the membrane .
the examples i looked but i don´t get permeation of hidrogeno.(2D) I put a domain where the fluid goes in direction axial but the right domain is a porous membrane so the fluid to have goes also in direcction radial and third domain is permeation and goes in direcction velocity axial. My example is similary a dialysis but my driving force is the pressure and i don´t get across the membrane .
