Mirror 3D for just one domain
I am using a symmetric model of a heat sink with forced cooling. I want my final figure to be the solid body of the heat sink without the fluid field, however, when I mirror 3d it mirrors all domains. How do I change this?
2 Replies Last Post 3 nov. 2014, 10:04 UTC−5
Posted: 1 decade ago 3 nov. 2014, 02:14 UTC−5
Do as follows:
- Select the solution data set that you want to mirror.
- Right-click and select Duplicate from the context menu.
- Select the data set that was created.
- Right-click and select Add Selection.
- In the Selection node: Change geometric entity level to Domain and select the domains that you are interested in.
- Go to the mirror data set and change its Data set setting to the data set with the selection.
Do as follows: - Select the solution data set that you want to mirror. - Right-click and select Duplicate from the context menu. - Select the data set that was created. - Right-click and select Add Selection. - In the Selection node: Change geometric entity level to Domain and select the domains that you are interested in. - Go to the mirror data set and change its Data set setting to the data set with the selection.
Posted: 1 decade ago 3 nov. 2014, 10:04 UTC−5
That did the trick! Thank you very much for your reply
