How to get the value in the 'Arrow Surface'
I use the 'Arrow Surface' to scale my variable and the result is good.
BUT HOW I can get the specific value of my variable ?
I want to get the value in the position of every arrow tail.
THANKS!
2 Replies Last Post 15 oct. 2014, 03:42 UTC−4
Posted: 10 years ago 15 oct. 2014, 02:27 UTC−4
Do as follows:
1. Select the Arrow Surface node in the Model Builder.
2. Right-click and select "Add Plot Data to Export" from the context menu.
3. In the Plot node that is created under Results > Export: Browse to a filename and click on Export.
Do as follows: 1. Select the Arrow Surface node in the Model Builder. 2. Right-click and select "Add Plot Data to Export" from the context menu. 3. In the Plot node that is created under Results > Export: Browse to a filename and click on Export.
Posted: 10 years ago 15 oct. 2014, 03:42 UTC−4
THANKS!I have solved my problem
