Two Phase Fluid Flow Convergence Error half-way into solution
Hi All,
Time dependent solver for Laminar Two-Phase Flow, Level Set crashes half-way through the solution with error message "last time step didn't converge". Do you know what could cause this? The geometry is a simple y-junction. The mesh is user controlled and done by creating distributions (rectangular) and sweeping them.
0 Replies Last Post 29 sept. 2014, 12:59 UTC−4
Hello Melaku Wol
