Difference between Outlet and Open Boundary condition for fluid flow
Hi everyone,
I was wondering if one of you could explain the difference between the outlet and open boundary condition for fluid flow (single phase k-e).
I've gone through the CFD manual but I can't visualize for which scenario's I would use one or the other.
Thank you for your help.
Victor
2 Replies Last Post 29 sept. 2014, 15:02 UTC−4
Posted: 1 decade ago 29 sept. 2014, 14:38 UTC−4
when you have a doubt like that, turn on the "equation settings and the equations view" (under "options", or top border icon of physics tree) and check the underlying equations of COMSOL, in both the Equation tab, and the equation view node.
An "open boundary" allow two-way flow with free pressure and velocity definition. The "outlet" requires an output pressure or velocity, with or no backflow suppression and/or normal flow conditions ... it's all written
Good luck,
Hi when you have a doubt like that, turn on the "equation settings and the equations view" (under "options", or top border icon of physics tree) and check the underlying equations of COMSOL, in both the Equation tab, and the equation view node. An "open boundary" allow two-way flow with free pressure and velocity definition. The "outlet" requires an output pressure or velocity, with or no backflow suppression and/or normal flow conditions ... it's all written -- Good luck, Ivar
Posted: 1 decade ago 29 sept. 2014, 15:02 UTC−4
Hi Ivar,
Thank you for replying so fast. I look at the equations but I have the follwing doubt.
Setting the pressure to zero in the outlet node should give the same results as the open boundary.
Its introduced in the comsol 4.4 intro as being more stable and improving mass conservation. So I'm hoping people who've used both could share their thoughts on why they used them.
Hope to hear more from you.
Hi Ivar, Thank you for replying so fast. I look at the equations but I have the follwing doubt. Setting the pressure to zero in the outlet node should give the same results as the open boundary. Its introduced in the comsol 4.4 intro as being more stable and improving mass conservation. So I'm hoping people who've used both could share their thoughts on why they used them. Hope to hear more from you.
