Problem current modelling for ring core inductor (axialsymmetrical)
Posted 18 sept. 2014, 10:44 UTC−4 Low-Frequency Electromagnetics Version 4.4 4 Replies
I am trying to model a ring core inductor.
For the winding I do not assume discrete turns but a kind of toroid with the ring core within the toroid. In this way I can model the inductor in 2d with axialsymmetrical (at least I think so)
However, I don't get reasonable result.
The winding is modelled by a circle with a surface current density, which is divided by the factor 2*pi*r to provide current conversation. By plotting the surface current density I can verify that my modelling of the current is correct.
However the solver does not converge for the stationary case. Since I want to calculate the eddy current losses in the core I also simulate in frequency domain. Depending on the frequencies the solver converges with a solution (i.e. for 900kHz with a skin constant of 0.1m where my ring core has got ID 20mm OD 34mm and height 13mm) but not always.
I also tried gauge fixing without any success.
I calculate with an in-plane vector potential.
I have attached my model. Simulation in 3d gives me more or less the same problem. If I model the winding with discrete turns (for example 10) the model doesn't converge either.
Since I have tried many different ways I think a make serious mistake in my model building and seem to violate some basic principle.
Grateful for help
Stefan Herzog
Grateful for help
Stefan Herzog
4 Replies Last Post 19 sept. 2014, 06:30 UTC−4
