Failed to find Solution
I'm new at COMSOL and am having an issue using the simulator. I think it should be a relatively simple problem. I'm trying to simulate the stresses inside this thing I made after bringing it from a high temperature, like 600C or so, to room temperature. That's the final goal anyway. As of now though I'm just trying to get any sort of simulation to work. I get an error that's as follows:
The following feature has encountered a problem:
Failed to find a solution.
In segregated group 1:
The relative error (.41) is greater than the relative tolerance.
-Feature: stationary Solver 1(sol1/s1)
-Error: Failed to find a solution.
This is what's in my log:
Stationary Solver 1 in Solver 1 started at 8-Sep-2014 18:13:34.
Segregated solver
Number of degrees of freedom solved for: 91104.
Segregated solver iteration 1.
Substep 1, for group 1.
Symmetric matrices found.
Scales for dependent variables:
mod1.u: 1
Iter Damping Stepsize #Res #Jac #Sol
1 1.0000000 0.97 1 1 1
Stationary Solver 1 in Solver 1: Solution time: 1 s.
Attached is my file.
Thank you for any help.
0 Replies Last Post 8 sept. 2014, 18:22 UTC−4
Hello Paul C
