how to add time dependent heat source
I am kinda new with COMSOL. I am wondering how to add time dependent heat source.
I have a 2D geometry, and a heat source in the center of the geometry.
I would like to have a time-varied heat source (in total power), and do time dependent simulation.
5 Replies Last Post 2 sept. 2014, 04:53 UTC−4
Posted: 1 decade ago 29 août 2014, 10:34 UTC−4
So you want something like q=f(t) or Tsource=f(t)? What should f look like?
Posted: 1 decade ago 30 août 2014, 00:10 UTC−4
I would like the f(t) to be a Sin() function.
Posted: 1 decade ago 1 sept. 2014, 02:33 UTC−4
Then you can put for the parameter of the heat source that you want to vary with time just something like 'A*sin(B*t)+C', where you replace A, B and C with actual numbers, or you define them as parameters beforehand.
Posted: 1 decade ago 1 sept. 2014, 22:42 UTC−4
Thank you for your help. I understand the approach in general. However, would you please give a little more step-by-step guide?
Thanks again.
[QUOTE] Then you can put for the parameter of the heat source that you want to vary with time just something like 'A*sin(B*t)+C', where you replace A, B and C with actual numbers, or you define them as parameters beforehand. [/QUOTE] Thank you for your help. I understand the approach in general. However, would you please give a little more step-by-step guide? Thanks again.
Posted: 1 decade ago 2 sept. 2014, 04:53 UTC−4
Can you then maybe upload your model so that I can use that as a starting point for the steps that you have to do? And what parameter of your heat source do you want to vary with time? Temperature? Heat flux? Something else?
