Squeeze Film Damping and Fluid Flow Deformation issues
Posted 22 juil. 2014, 19:26 UTC−4 MEMS & Nanotechnology, MEMS & Piezoelectric Devices, Structural Mechanics Version 4.4 0 Replies
My laminar fluid flow has similar symptoms:
While I was still struggling with the MEMS module I tried to model the same structure in laminar flow (Based on "Obstacle in a Fluid" example) with an inlet velocity of 4E-7m/s and outlet pressure of 0 and I was having similarly small values of deformation at the end of the beam, 1E-12 m ballpark.
I know these are different modules since the symptoms are similar I thought I might combine them.
Here are the basics of my setup:
The beam is only constrained on one end with a fixed constraint.
The whole object is selected as "Prescribed Deformation'
Hello Logan Garbarini
