16 mai 2014, 03:46 UTC−4
I am not sure how to program per time step, because I think in general COMSOL chooses it's own time steps. What is your variable T? I can immagine that A(T) would have to depend on the size of your time step, so is T the size of your time step? I would linearize A(T), so it would be approximately equal to A(0)+T*(dA/dT)_0, which always holds if your time step is sufficiently small ((dA/dT)_0 is dA/dT calculated at T=0). Then you would have
(F(t+T)-F(t))=A(T)=A(0)+T*(dA/dT)_0
dividing both sides by T you get
(F(t+T)-F(t))/T=A(0)/T+(dA/dT)_0
The left hand side is the definition of the differential, so you would get
dF/dt=A(0)/T+(dA/dT)_0
Which shows that A should approach 0 when your time step approaches 0, otherwise A(0)/T will be infinite. So A(0)=0 so
dF/dt=(dA/dT)_0
I would say that such a differential equation can be implemented somewhere in your model.
dF/dt=(dA/dT)_0
16 mai 2014, 15:45 UTC−4
thank you Pieter
My variable is not T, is the potential applied to a pipeline (potential cathodic protection E_CP).
I testing the potential of the electrolyte Eoff for each time step.
And if Eoff> -0.85 V, I must impose a new E_CP (potential protection) = previous E_PC - 0.01 to pipeline intel Eoff becomes <-0.85 V.
My problem that I can not put E_PC = E_PC - 0.01 because Comsel not accept it !!
Is there a solution?
thank you Pieter
19 mai 2014, 03:27 UTC−4
Hi Babaghayou,
So what you want is that the potential of your pipeline is lowered when the potential of your electrolyte becomes too high? So what in your model controls the potential of your pipeline? If you would not have this check, would it be constant?
Hi Babaghayou,
19 mai 2014, 13:29 UTC−4
Hi pieter
In my model, the potential of pipeline (Eoff) is controled by "Domain Prob" and at each step of time give me the value of pipeline potential.
The potential Eoff depend to the potential of cathodic protection that I must increase or reduce if Eoff increase or reduce.
Hi pieter
19 mai 2014, 13:48 UTC−4
The Eoff must remain in value between Vmin and Vmax and if Eoff>Vmax or Eoff<Vmax , i increase or reduce the potential of protection for maintain Eoff between these two values.
20 mai 2014, 02:59 UTC−4
And how is this potential protection changed? Can you maybe upload your model?
