How to excite a Microstrip?
Dear community,
i am currently designing a microwave resonator consisting of microstrips.
Does anyone know how to put an excitation just along one strip, as in a coax cable without outer conductor?
I havent found that in any complete model.
The port and lumped port can only apply fields or voltages between two adjacent parts of my geometry, if i got it correctly.
Thank you a lot in advance
4 Replies Last Post 14 avr. 2014, 08:43 UTC−4
Posted: 1 decade ago 8 avr. 2014, 04:58 UTC−4
Hi Alex,
a coaxial cable with stripped off outer conductor can be seen like being excited by a lumped port between the end of the shield and the center wire.
Maybe you have to explain your requirements a little clearer, e.g. with a sketch
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Alex, a coaxial cable with stripped off outer conductor can be seen like being excited by a lumped port between the end of the shield and the center wire. Maybe you have to explain your requirements a little clearer, e.g. with a sketch Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 8 avr. 2014, 07:40 UTC−4
Thanks for your fast response!
If i just remove the outer conductor, I think there will be impedance matching troubles.
There are devices called coaxial to microstrip connector, but since there isnt something like that in comsol, I will try using an AC voltage as drawn in the PNG.
Is there a way to connect my resonator to the external circuit? There is no real 'port', the resonator is a thin layer of copper forming an omega.
Best regards
Alex
Thanks for your fast response! If i just remove the outer conductor, I think there will be impedance matching troubles. There are devices called coaxial to microstrip connector, but since there isnt something like that in comsol, I will try using an AC voltage as drawn in the PNG. Is there a way to connect my resonator to the external circuit? There is no real 'port', the resonator is a thin layer of copper forming an omega. Best regards Alex
Posted: 1 decade ago 8 avr. 2014, 09:28 UTC−4
How do you realize ground in your model? A microstrip has a ground plane under the strip.
Edgar J. Kaiser
www.emphys.com
How do you realize ground in your model? A microstrip has a ground plane under the strip. -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 14 avr. 2014, 08:43 UTC−4
as everytime after asking questions, I got some insights and ideas, so my model advanced, I attached it.
I wanted to make a microstrip similar to the goubau line, without ground plane, but then decided to realize the ground by another strip.
Could you please give me a hint how to improve my meshing? Solver warns me of low minimum element quality but i dont see any other possibility to sensibly resolve my structure.
Is there an option to find the resonance frequency instead of searching the maximum of
(Pport_1-Pelement_1)/Pport_1?
I would be again really glad if u could help me
cheers
Alex
Hi, as everytime after asking questions, I got some insights and ideas, so my model advanced, I attached it. I wanted to make a microstrip similar to the goubau line, without ground plane, but then decided to realize the ground by another strip. Could you please give me a hint how to improve my meshing? Solver warns me of low minimum element quality but i dont see any other possibility to sensibly resolve my structure. Is there an option to find the resonance frequency instead of searching the maximum of (Pport_1-Pelement_1)/Pport_1? I would be again really glad if u could help me cheers Alex
