rescaling plots
Hello all,
I've already created my surface plot, and proposal is that observing water fluctuation in floodplain, so the wide of floodplain is 420 meter (x-direction) and water fluctuation is less that 2 meters.
Therefore, I will have line for the surface plot, but I want to have y axis in cm unit; how can I change the scale in axis?
using COMSOL 3.4 version.
Thanks in advance for your comments,
Sepideh
1 Reply Last Post 7 mars 2014, 08:46 UTC−5
Posted: 1 decade ago 7 mars 2014, 08:46 UTC−5
Hello all,
Sepideh
Also attached the snapshot
[QUOTE] Hello all, I've already created my surface plot, and proposal is that observing water fluctuation in floodplain, so the wide of floodplain is 420 meter (x-direction) and water fluctuation is less that 2 meters. Therefore, I will have line for the surface plot, but I want to have y axis in cm unit; how can I change the scale in axis? using COMSOL 3.4 version. Thanks in advance for your comments, Sepideh [/QUOTE] Also attached the snapshot
