node: Results/Datasets/Frame - difference between mesh, geometry,material and space ?
Within the results in the node: Results/Datasets/Frame there is the choice between: mesh, geometry,material and space ?
What is the difference and what is used in which case?
In my case only case is different, whild mesh, geometry and material seem to be identical in case of a deformation of the geometry. So the change in case of "space" seems to reflect the physical deformation and seems to reflect the new positions of the mesh-knots after deformation.
But what is the difference of the others?
4 Replies Last Post 19 févr. 2014, 05:05 UTC−5
Posted: 1 decade ago 18 févr. 2014, 01:56 UTC−5
This is described in the 'About Frames' section in the COMSOL Multiphysics Reference Manual.
Henrik
Hi, This is described in the 'About Frames' section in the COMSOL Multiphysics Reference Manual. Regards, Henrik
Posted: 1 decade ago 18 févr. 2014, 14:19 UTC−5
Thank You.
Do You mean the "COMSOL Multiphysics User's Guide"? (There I find some explanation.)
Otherwise arises the question: Where do I find the "Reference Manual"?
Thank You. Do You mean the "COMSOL Multiphysics User's Guide"? (There I find some explanation.) Otherwise arises the question: Where do I find the "Reference Manual"?
Posted: 1 decade ago 19 févr. 2014, 02:23 UTC−5
In the 4.4 documentation:
COMSOL Multiphysics->COMSOL Multiphysics Reference Manual->Deformed Geometry and Moving Mesh->Deformed Mesh Fundamentals->About frames
Henrik
In the 4.4 documentation: COMSOL Multiphysics->COMSOL Multiphysics Reference Manual->Deformed Geometry and Moving Mesh->Deformed Mesh Fundamentals->About frames Regards, Henrik
Posted: 1 decade ago 19 févr. 2014, 05:05 UTC−5
Ahhh OK, it's found in the help function of the program, not in a book.
Thank You,
Best regards
Hans
Ahhh OK, it's found in the help function of the program, not in a book. Thank You, Best regards Hans
