About shock tube model
Hi there,
I have going through the shock tube model: www.comsol.com/showroom/gallery/100/ but I found something strange: should not the pressure wave reach the boundaries (3m tube) in the order of milisenconds? In the results it shows that even after 1 second the wave have not arrive... I am missing something???
Thanks!
7 Replies Last Post 1 oct. 2012, 04:10 UTC−4
Hello André Cordeiro
Posted: 1 decade ago 1 déc. 2011, 04:33 UTC−5
You are right. I never thought about that! Probably y is not the real time, but some dimensionless number related to time. Support should helb you with that.
Fabio
You are right. I never thought about that! Probably y is not the real time, but some dimensionless number related to time. Support should helb you with that. Fabio
Posted: 1 decade ago 13 déc. 2011, 19:12 UTC−5
Hi!!!
I've been going through that model also and I guess they worked with non-dimensional NS equations, although the dimensions of the geometry are marked as lenght units.
Another curiosity is that the model doesn't seem to handel with greater amplitudes on the step function. In real experiments I believe that the driver zone reaches pressures higher than twice the one of the driven zone (which usually is kept at atmosferic pressure).
Have you tried to contact the Comsol's support??
If you have any information about this model that you could share I would be very appreciated.
Pedro Santos
Hi!!! I've been going through that model also and I guess they worked with non-dimensional NS equations, although the dimensions of the geometry are marked as lenght units. Another curiosity is that the model doesn't seem to handel with greater amplitudes on the step function. In real experiments I believe that the driver zone reaches pressures higher than twice the one of the driven zone (which usually is kept at atmosferic pressure). Have you tried to contact the Comsol's support?? If you have any information about this model that you could share I would be very appreciated. Pedro Santos
Posted: 1 decade ago 14 déc. 2011, 04:29 UTC−5
Hi!!!
I tryed to use the model for other gammas (1.1), but I also have divergence problems.
I asked the support for the case of gamma 1.4 with a pressure ratio of 20/1 and they did it for me.
So I think just ask and they will solve it for you.
Bye,
Fabio
Hi!!! I tryed to use the model for other gammas (1.1), but I also have divergence problems. I asked the support for the case of gamma 1.4 with a pressure ratio of 20/1 and they did it for me. So I think just ask and they will solve it for you. Bye, Fabio
Posted: 1 decade ago 14 déc. 2011, 05:37 UTC−5
Hi!!
Thanks for the reply. Is to good to know that one can get result for such pressure ratios. I just wonder what were the changes they've made to the model. I've tried many things and nothing worked except for the use of a bigger domain. Could you send me the model file??
Thanks.
Pedro Santos
Hi!! Thanks for the reply. Is to good to know that one can get result for such pressure ratios. I just wonder what were the changes they've made to the model. I've tried many things and nothing worked except for the use of a bigger domain. Could you send me the model file?? Thanks. Pedro Santos
Posted: 1 decade ago 14 déc. 2011, 05:50 UTC−5
I will send you a private message with my e-mail address!
Fabio
I will send you a private message with my e-mail address! Fabio
Posted: 1 decade ago 17 sept. 2012, 09:10 UTC−4
Hi!
Have you solved the model with a higher pressure ratio. I met the same problem during my study, which troubled me for several weeks. could you give me some advice?
Thank you very much for the help!
Jian Wu
Hi!!!
Bye,
Fabio
Hi! Have you solved the model with a higher pressure ratio. I met the same problem during my study, which troubled me for several weeks. could you give me some advice? Thank you very much for the help! Jian Wu [QUOTE] Hi!!! I tryed to use the model for other gammas (1.1), but I also have divergence problems. I asked the support for the case of gamma 1.4 with a pressure ratio of 20/1 and they did it for me. So I think just ask and they will solve it for you. Bye, Fabio [/QUOTE]
Posted: 1 decade ago 1 oct. 2012, 04:10 UTC−4
As I suggested, ask the support, they did it for me and I think they will do it for you!
Fabio
As I suggested, ask the support, they did it for me and I think they will do it for you! Fabio
