Unexpected error occured whenever I click on a field for text input in tables
I've recently installed a copy of COMSOL 4.2 on Mac OS 10.8.5. The program runs fine except that an error message would pop up whenever I need to edit a text field in a table, such as parameters and variables. However other text fields are fine, such as the blanks you need to fill for various variables in the modules. For now the solution I have is to edit those tables in a windows version, and transfer the model file to my computer and run it.
Please see the last section of the log file as follows. As is indicated by the error message, which says un expected error occured, the detail of this error can be found at the end of the log file. However I'm unable to decypher what the log file says.
I would really appreciate any help with this.
00065:566 ERROR at com.comsol.widgets.tk.swt.swttable.f.a(Unknown Source) [com.comsol.logger]
00065:567 ERROR at com.comsol.widgets.tk.swt.swttable.SWTTable.a(Unknown Source) [com.comsol.logger]
00065:567 ERROR at com.comsol.widgets.tk.swt.swttable.e.handleEvent(Unknown Source) [com.comsol.logger]
00065:568 ERROR at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) [com.comsol.logger]
00065:568 ERROR at org.eclipse.swt.widgets.Display.sendEvent(Display.java:3783) [com.comsol.logger]
00065:568 ERROR at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1375) [com.comsol.logger]
00065:569 ERROR at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1398) [com.comsol.logger]
00065:569 ERROR at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1383) [com.comsol.logger]
00065:569 ERROR at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1195) [com.comsol.logger]
00065:569 ERROR at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3629) [com.comsol.logger]
00065:570 ERROR at org.eclipse.swt.widgets.Display.applicationNextEventMatchingMask(Display.java:4486) [com.comsol.logger]
00065:570 ERROR at org.eclipse.swt.widgets.Display.applicationProc(Display.java:4746) [com.comsol.logger]
00065:575 ERROR at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method) [com.comsol.logger]
00065:575 ERROR at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:220) [com.comsol.logger]
00065:576 ERROR at org.eclipse.swt.widgets.Widget.mouseDownSuper(Widget.java:1025) [com.comsol.logger]
00065:576 ERROR at org.eclipse.swt.widgets.Table.mouseDownSuper(Table.java:1937) [com.comsol.logger]
00065:576 ERROR at org.eclipse.swt.widgets.Widget.mouseDown(Widget.java:1021) [com.comsol.logger]
00065:576 ERROR at org.eclipse.swt.widgets.Control.mouseDown(Control.java:2263) [com.comsol.logger]
00065:577 ERROR at org.eclipse.swt.widgets.Table.mouseDown(Table.java:1909) [com.comsol.logger]
00065:577 ERROR at org.eclipse.swt.widgets.Display.windowProc(Display.java:4983) [com.comsol.logger]
00065:577 ERROR at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method) [com.comsol.logger]
00065:577 ERROR at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:220) [com.comsol.logger]
00065:577 ERROR at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:1959) [com.comsol.logger]
00065:578 ERROR at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:2025) [com.comsol.logger]
00065:578 ERROR at org.eclipse.swt.widgets.Display.windowProc(Display.java:5047) [com.comsol.logger]
00065:578 ERROR at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method) [com.comsol.logger]
00065:578 ERROR at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:4589) [com.comsol.logger]
00065:579 ERROR at org.eclipse.swt.widgets.Display.applicationProc(Display.java:4666) [com.comsol.logger]
00065:579 ERROR at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method) [com.comsol.logger]
00065:579 ERROR at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication.java:115) [com.comsol.logger]
00065:579 ERROR at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3281) [com.comsol.logger]
00065:579 ERROR at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640) [com.comsol.logger]
00065:580 ERROR at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604) [com.comsol.logger]
00065:580 ERROR at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438) [com.comsol.logger]
00065:580 ERROR at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671) [com.comsol.logger]
00065:580 ERROR at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) [com.comsol.logger]
00065:581 ERROR at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664) [com.comsol.logger]
00065:581 ERROR at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) [com.comsol.logger]
00065:581 ERROR at com.comsol.gui.swt.SWTDesktop.open(Unknown Source) [com.comsol.logger]
00065:581 ERROR at com.comsol.gui.DesktopWindow.open(Unknown Source) [com.comsol.logger]
00065:581 ERROR at com.comsol.gui.CsApplication.startApplication(Unknown Source) [com.comsol.logger]
00065:582 ERROR at com.comsol.gui.CsApplication.doStart(Unknown Source) [com.comsol.logger]
00065:582 ERROR at com.comsol.guimph.MphApplication.doStart(Unknown Source) [com.comsol.logger]
00065:582 ERROR at com.comsol.util.application.ComsolApplication.doStart(Unknown Source) [com.comsol.logger]
00065:582 ERROR at com.comsol.util.application.CsBaseApplication.start(Unknown Source) [com.comsol.logger]
00065:582 ERROR at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) [com.comsol.logger]
00065:583 ERROR at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) [com.comsol.logger]
00065:583 ERROR at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) [com.comsol.logger]
00065:583 ERROR at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369) [com.comsol.logger]
00065:583 ERROR at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) [com.comsol.logger]
00065:584 ERROR at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [com.comsol.logger]
00065:584 ERROR at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) [com.comsol.logger]
00065:584 ERROR at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) [com.comsol.logger]
00065:584 ERROR at java.lang.reflect.Method.invoke(Method.java:597) [com.comsol.logger]
00065:584 ERROR at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620) [com.comsol.logger]
00065:585 ERROR at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575) [com.comsol.logger]
00065:585 ERROR at org.eclipse.equinox.launcher.Main.run(Main.java:1408) [com.comsol.logger]
Wei Wang, Ph.D.
3 Replies Last Post 5 juin 2014, 12:15 UTC−4
Hello Wei "Tiger" Wang
Posted: 1 decade ago 21 nov. 2013, 06:28 UTC−5
I have the same problem.
Did you find a solution?
I have the same problem. Did you find a solution?
Posted: 1 decade ago 23 avr. 2014, 10:15 UTC−4
I have the same problem but are unable to find solution?
Posted: 1 decade ago 5 juin 2014, 12:15 UTC−4
I also meet the same problem when I draw the Arrow surface. I have asked a lot of people who is expert for comsol modeling, our final conclusion is that it is due to the bug of comsol. We should ask this question to the comsol company.
Wenjia
I also meet the same problem when I draw the Arrow surface. I have asked a lot of people who is expert for comsol modeling, our final conclusion is that it is due to the bug of comsol. We should ask this question to the comsol company. Wenjia
