Nagi Elabbasi
Facebook Reality Labs
18 oct. 2013, 08:58 UTC−4
Dear Li,
It depends on the source of the damping and the type of analysis you need (frequency or time domain). For such problems damping could be mainly due to the air in which case you need a structural acoustic model, or it could be material damping in the solid in which case you just need a structural model, or it could be both! The options available for handling the damping depend on whether you are solving in the time or frequency domain. You may need the Acoustics, Structural Mechanics or the MEMS module depending on the details.
Nagi Elabbasi
Veryst Engineering
Dear Li,
Nagi Elabbasi
Veryst Engineering
20 oct. 2013, 22:10 UTC−4
Dear Nagi Elabbasi
thanks very much for your help,the damping is from the friction between the air and the resonator , I want to use the time domain mode solution, could you tell me how to use?
Dear Nagi Elabbasi
Nagi Elabbasi
21 oct. 2013, 17:57 UTC−4
Dear Li,
Friction between the air and the resonator is a viscous loss. You can account for that in a transient analysis using the Acoustics module. In the Transient Pressure Acoustics Model settings select Fluid model = Viscous.
Nagi Elabbasi
Veryst Engineering
Dear Li,
Nagi Elabbasi
Veryst Engineering
