Relative Energy from Eigenfrequency Analysis
Hello All,
I have been working with COMSOL 4.0 (mostly heat transfer modules) but now need to analyze a structure with an eigenfrequency analysis.
I can generate the model and the eigenfrequency(s), but I would like to end up with the results presented as a plot of frequency vs energy.
Anybody know the steps I need to take using 4.0a?
Thanks Everyone
1 Reply Last Post 9 oct. 2013, 14:15 UTC−4
Posted: 1 decade ago 9 oct. 2013, 14:15 UTC−4
Hi Brandon,
this has often been discussed in this forum. An eigenmode or eigenfrequency is essentially a mathematical property of the system. It has a certain shape but it doens't have a certain energy or amplitude. The deformations you see in the plots are arbitrary.
If you want to evaluate energies or amplitudes you have to run a frequency domain study and excite the system some way.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Brandon, this has often been discussed in this forum. An eigenmode or eigenfrequency is essentially a mathematical property of the system. It has a certain shape but it doens't have a certain energy or amplitude. The deformations you see in the plots are arbitrary. If you want to evaluate energies or amplitudes you have to run a frequency domain study and excite the system some way. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
