Edgar J. Kaiser
Certified Consultant
23 sept. 2013, 09:43 UTC−4
an ellipse can easily be parameterized. See:
en.wikipedia.org/wiki/Ellipse
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
an ellipse can easily be parameterized. See: http://en.wikipedia.org/wiki/Ellipse
Cheers
Edgar
Edgar J. Kaiser
23 sept. 2013, 10:34 UTC−4
Thank you for your response but that's not what I mean. A parameterized curve is described by a formula and the radius is obtained from that formula. I want to be able to draw a curve without needing to describe it by a formula and then obtain the radius.
Later I want to alter the geometry in such a way that it gets really complicated to describe it by parameterization, that's why I want to define the radius in a different way.
24 sept. 2013, 09:48 UTC−4
I don't think there is a built in function within comsol to do this for you (not sure if this is what you were asking). You would have to provide the eqn's. As far as simple functions go, there are equations that describe circles, ellipses, etc but if the geometry gets into an unknown shape you would have to guess at a possible eqn for the curve.
Just as an example, this has the eqn's for an ellipse
www.mathwarehouse.com/ellipse/equation-of-ellipse.php
For solving of two unknowns (x and y here) and since you have two eqns you should be able to do this provided you know all of the other variables.
The other option in comsol is that if you draw a 2D object, you could divide up the object such that you get, say, 4 partitions for a circle (simple example). This way, comsol could provide with the radius but you would have to highlight those lines in the postprocessor.
I don't know if this really answers your question well enough.
http://www.mathwarehouse.com/ellipse/equation-of-ellipse.php
24 sept. 2013, 10:15 UTC−4
that's indeed what I'm asking.
Comsol is able to show the solution of the radius of a curve using '1D plot group' -> 'Line graph', select the curve and plot sqrt(x^2+y^2) or sys1.r against the angle. I'm figuring out if I can make the same plot using a global plot where the expression implements the curve in some way. I thought this wouldn't be such a big deal in Comsol, like if the ellipse is called 'e1' that you could use 'e1.x' to find the x coordinates of that ellipse. But it doesn't seem to work that way.
I guess I'll then have to describe each curve with formula's and use for example your idea of partitions of a circle (or maybe boolean operators for the 4 quadrants. I'll try something.
Ellipse equation is indeed like below, but that's not my concern.
upload.wikimedia.org/math/0/3/1/031474cb80469619a7abff7d32dc7e4a.png
anyway, thank you for your reply
http://upload.wikimedia.org/math/0/3/1/031474cb80469619a7abff7d32dc7e4a.png
