Fillet Weld Deformation Model
I am trying to model the deformation of a fillet weld after heating and cooling, however I am having issues making such a model work.
At this point I am using Thermal Stress with a simple 2D model, two plates with a triangle as the weld metal. I am heating the weld metal, and then trying to have it cool through heat flux off the inside surfaces.
I am able to get it down to a lower temperature, but my the only deformation I am finding is expansion from heating, but from cooling it should have caused the plate to bend in, not out.
Any help on how I could get this to work properly would be appreciated. I am not very experience in COMSOL at all, if that wasn't obvious already.
1 Reply Last Post 14 août 2013, 17:31 UTC−4
Josh Thomas Certified Consultant
Posted: 1 decade ago 14 août 2013, 17:31 UTC−4
Derek,
From probing your results for displacement of the upper tip of the plate, your results show that during the heating (0 to 1 sec) the top of the plate bends out (to the left) and during cooling (1 sec to 10 sec) the plate bends back to vertical.
I'm not sure why you say that the plate bends "in" from cooling.
When making conclusions about displacements it is good to probe the actual numeric values of points or lines rather than relying on the visualization of the deformation. Unless you are sure that the deformation "scale factor" scaling is set to 1 via the check box and edit field in the Settings window. This may be what caused you to come to an incorrect conclusion about your results.
Josh Thomas
AltaSim Technologies
Derek, From probing your results for displacement of the upper tip of the plate, your results show that during the heating (0 to 1 sec) the top of the plate bends out (to the left) and during cooling (1 sec to 10 sec) the plate bends back to vertical. I'm not sure why you say that the plate bends "in" from cooling. When making conclusions about displacements it is good to probe the actual numeric values of points or lines rather than relying on the visualization of the deformation. Unless you are sure that the deformation "scale factor" scaling is set to 1 via the check box and edit field in the Settings window. This may be what caused you to come to an incorrect conclusion about your results. Best regards, Josh Thomas AltaSim Technologies
