find the coordinates of a point in which the magnitude of derived variable at a specific time is minimum?
I am working on a 2D transient problem. I have the results and want to post processing them.
I want to plot my results like this:
Detect the minimum of a derived variable all over the domain at a specific time.
then, again detect that variable in another time (and repeat it for my time period)
I could do that. Now I wanna to have the coordinates of that point in which the derived variable is minimum at that specific time.
Any idea?
Hooman
4 Replies Last Post 6 juin 2013, 15:03 UTC−4
Posted: 1 decade ago 10 mai 2013, 02:02 UTC−4
if you are working with Matlab ti's really easy: you have the solution at certain time t stored into a column vector, and you fond the minimum. You should know the position in the column vector in which the minimum is stored. Let's say a the n-th row.
Now extract the vector with X-Y coordinates of your nodes: at the position n you will find the coordinates of your minimum.
Good luck ;)
Mattia
Hello, if you are working with Matlab ti's really easy: you have the solution at certain time t stored into a column vector, and you fond the minimum. You should know the position in the column vector in which the minimum is stored. Let's say a the n-th row. Now extract the vector with X-Y coordinates of your nodes: at the position n you will find the coordinates of your minimum. Good luck ;) Mattia
Posted: 1 decade ago 10 mai 2013, 06:27 UTC−4
Mattia,
Thanks for the reply. What if I do not use Live link?
Can I do it within the software?
Mattia, Thanks for the reply. What if I do not use Live link? Can I do it within the software? Thanks
Posted: 1 decade ago 10 mai 2013, 08:03 UTC−4
honestly I don't have experience with it myself, but I guess it is possible. What I'd do is to write down an equation while defining the plot....
Sorry, I can't help much..but that's who I'd do it :-)
Mattia
Hi, honestly I don't have experience with it myself, but I guess it is possible. What I'd do is to write down an equation while defining the plot.... Sorry, I can't help much..but that's who I'd do it :-) Mattia
Posted: 1 decade ago 6 juin 2013, 15:03 UTC−4
Mattia,
I found it!
just under Results-derived values right click and then choose minimum and then volume or surface minimum.
Hooman
Mattia, I found it! just under Results-derived values right click and then choose minimum and then volume or surface minimum. Hooman
