4 mai 2013, 06:16 UTC−4
perhaps it's simply that your initial conditions are too far from the solution so jumping straight to 6kA is too stiff, have you tried to use a step function and let COMSOL ramp up the current from nearly 0 to your max value with a smmoth step or ramp ?, in 3-10 steps ?
4 mai 2013, 06:30 UTC−4
Hi Ivar, and thanks for answering!
So, the problem might be about to coil, passing from 0 W to 6000 W in a smallest time step?
PS: why you talked about current and not power?
4 mai 2013, 07:04 UTC−4
just a glimps, I usually increase current in coils, but you are right it can also be power ;) Whatever drives your model. Do not forget that mesh, time steps and gradients are often linked by some fundamental formulas, so too steep gradients with finite mesh gives sometimes issues for the solver convergence. For that the parametric sweep are useful to help convergence, and to follow what is happening (use the plot while solving ...)
4 mai 2013, 09:20 UTC−4
Thanks again Ivar for you support!
I read that setting power as input induces nonlinear equations, so could be better to set current.
But i would set both voltage and current, because if i set just one of them i don't know which value has the other one.
How i can do it? If i set current, there is a setting that allow me to set voltage too?
5 mai 2013, 05:38 UTC−4
any ideas?
any ideas?
