Large deformation - compression
Hello!
I am a newbie at Comsol programming, trying to come to terms with the program. I have a very simple model of a material under compression. The material (should) undergo large deformation when put under pressure. I have modelled this with a larger steel rectangle pressing down onto a smaller rectangle of my material (human tissue, with values taken from literature). This works fine when I am running the program with "small" deformations (ab 12% of the height of the tissue/deforming material). If I try and displace it further ( I would ideally want to reach 50% height deformation (ie, that the material is 50 % "shorter" after compression)) it seems that the contact pairs I've created are overruled, and the deforming material does not move at all.
Am I trying to deform it too much without using the equations for hyperelastic materials?
I have attached my (very simple!) model to the message, if anyone has any comments/suggestions please let me know!
anna
2 Replies Last Post 24 avr. 2013, 06:19 UTC−4
Posted: 1 decade ago 24 avr. 2013, 05:46 UTC−4
I'm not by my WS so I cannot open your model, but have you at least turned ON the non-linear geoemty setting in the solver setting ? (probably, by default if you have "contact physics" defined)
Hi I'm not by my WS so I cannot open your model, but have you at least turned ON the non-linear geoemty setting in the solver setting ? (probably, by default if you have "contact physics" defined) -- Good luck Ivar
Posted: 1 decade ago 24 avr. 2013, 06:19 UTC−4
Hiya!
Thanks for the fast response. Yes, non-linear geometry is turned on :)
/anna
Hiya! Thanks for the fast response. Yes, non-linear geometry is turned on :) /anna
