Impedance mismatch in quasistatic
Posted 19 avr. 2013, 07:16 UTC−4 Low-Frequency Electromagnetics, Modeling Tools & Definitions, Parameters, Variables, & Functions 2 Replies
Hello everybody!
I need the help of people familiar with AC/DC and RF module. I am working with a 3D structure consisting of 2 pads, 100um*200um*0.2um, separated by a 1um slot line. The pad are shorted at one end (5-20um wide strip) and connected by 25um diameter cylinders from the top on the other end where I want to put my terminal and ground.
I am working at 10 GHz so, because the electrical size of my system is around 1/100, i used the AC DC module, magnetic and electrical field. this pattern is laid on top of a 0.5 SiO2 layer and 100um Si layer.
My question:
Does Comsol in these conditions take into account the reflection due to impedance mismatches when calculating the current and the fields in the slotline?
I am not so sure what i should expect here because the system is small and the usual calculation of slotline impedance say that it depends on the width of the slotline, and here the admittance yielded does not depends much on it.
What do you think?
Thanks for your help!
My question:
What do you think?
2 Replies Last Post 19 avr. 2013, 07:56 UTC−4
