Induced charge on a surface by a charged object at different relative positions
I am new in COMSOL and I was wondering if anyone could five me any idea. I want to simulate the evolution of the induced charge on a surface as the relative position to a charged object varies, this variation must be parametrized by the user and not due to the electrostatic effects. My first idea was to parametrize the position of one object as a function of time but i couldn't. Is possible to do it in any other way? Thank you very much in advance!
Gerard
3 Replies Last Post 15 avr. 2013, 10:15 UTC−4
Posted: 1 decade ago 12 avr. 2013, 07:18 UTC−4
Gerard,
you can parameterize the position of an object in a stationary study. You have to add a parametric sweep to the study and choose a range for the position parameter. This will generate the geometry and the mesh in each parameter loop.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Gerard, you can parameterize the position of an object in a stationary study. You have to add a parametric sweep to the study and choose a range for the position parameter. This will generate the geometry and the mesh in each parameter loop. Cheers Edgar -- Edgar J. Kaiser http://www.emphys.com
Posted: 1 decade ago 12 avr. 2013, 08:52 UTC−4
you can parametrise with a "global Parameter" that changes the geometry position and do a stationary analysis to see the charge distribution in ES, or you charge your system, and in EC with conduction you do a transient analysis to see how things decay by condition.
Else in steady state sinus excitation you have the frequency response versus given positions, ...
Hi you can parametrise with a "global Parameter" that changes the geometry position and do a stationary analysis to see the charge distribution in ES, or you charge your system, and in EC with conduction you do a transient analysis to see how things decay by condition. Else in steady state sinus excitation you have the frequency response versus given positions, ... -- Good luck Ivar
Posted: 1 decade ago 15 avr. 2013, 10:15 UTC−4
Hi Edgar and Ivar,
It works perfectly. Thank you so much!
Best Regards
Gerard
Hi Edgar and Ivar, It works perfectly. Thank you so much! Best Regards Gerard
