Drawing a sinusoidal wave in COMSOL
Hello;
How can I draw a sinusoidal wave as a part of a geometry in COMSOL?
Thanks for your help.
Sincerely;
Uldouz
2 Replies Last Post 24 mars 2013, 15:10 UTC−4
Posted: 1 decade ago 24 mars 2013, 14:35 UTC−4
what do you mean by sinus wave as part of a geoemtry ? you mean shape that has a sinus type wave on it i.e.e intnikness ?
If yo, I would try to dgitise it in as a interpolation function and use that to shape your bezier line, or use a first ODE physics to build the sinus from a straight plane via ALE or other to define a shpae, then remesh, save as geoemtry and go on (there is somewhere "GrandMa's pie example, Linus showed it once at one of the EU conferences
Hi what do you mean by sinus wave as part of a geoemtry ? you mean shape that has a sinus type wave on it i.e.e intnikness ? If yo, I would try to dgitise it in as a interpolation function and use that to shape your bezier line, or use a first ODE physics to build the sinus from a straight plane via ALE or other to define a shpae, then remesh, save as geoemtry and go on (there is somewhere "GrandMa's pie example, Linus showed it once at one of the EU conferences -- Good luck Ivar
Posted: 1 decade ago 24 mars 2013, 15:10 UTC−4
Hi Dear Ivar,
Actually I want to draw a silicon waveguide that its width is modulated as sinus wave. Namely, waveguide width is varied along propagation direction in the form of sinus function.
Sincerely,
Uldouz
Hi Dear Ivar, Thanks for your help. Actually I want to draw a silicon waveguide that its width is modulated as sinus wave. Namely, waveguide width is varied along propagation direction in the form of sinus function. Sincerely, Uldouz
