Problem in defining analytic function
Muthuraman Chinnadurai
Hello everyone,
Am working on electrostatics and had used an image function for my model. I am trying to define the relative permitivity of as a function of grey scale in image. But whwn i try to plot the function, the message i receive is "Invalid Lower bound, empty expression". I kindly request your good self to help me solve the issue, Thanks in advance!!!
1 Reply Last Post 23 mars 2013, 08:46 UTC−4
Posted: 1 decade ago 23 mars 2013, 08:46 UTC−4
if that happens in adefinition functions (i.e. analytical) it could come from a field i one of the lower (by default closed) tabs you define lower and upper bound of your variable for the plot check
Hi if that happens in adefinition functions (i.e. analytical) it could come from a field i one of the lower (by default closed) tabs you define lower and upper bound of your variable for the plot check -- Good luck Ivar
