Model conversion from 2d axi to regular 2d
Dear community,
I want to convert a 2d axisymmetric model into a regular 2d model.
Is that possible or do I need to setup the model again in 2d?
Many thanks,
Marcel
2 Replies Last Post 13 mars 2013, 04:59 UTC−4
Posted: 1 decade ago 13 mars 2013, 04:56 UTC−4
you need to set up the model again, but it's quickly done, you can save and reload the geometry, variables and parameters, and then open 2 COMSOl and cut & paste from one into the other
Hi you need to set up the model again, but it's quickly done, you can save and reload the geometry, variables and parameters, and then open 2 COMSOl and cut & paste from one into the other -- Good luck Ivar
Posted: 1 decade ago 13 mars 2013, 04:59 UTC−4
Thanks for the prompt answer :)
