Mesh study refinement plots
Hi everyone,
I'm running some mesh refinement studies and what I need is to have all curves (from each step of study) all together on one plot. Let's assume I'm not gonna utilize parametric sweet and just repeat the study every time for each mesh size. basically I have one plot for each step but I want to keep it and put the new curve on the last one so I can compare and make a result of it.
Thanks.
1 Reply Last Post 7 mars 2013, 17:17 UTC−5
Posted: 1 decade ago 7 mars 2013, 17:17 UTC−5
you add a subplot pointing to each data set, or you use the derived Variables nodes to calcualte some variable for each paraetric value
Hi you add a subplot pointing to each data set, or you use the derived Variables nodes to calcualte some variable for each paraetric value -- Good luck Ivar
